Had this issue since we bought it last year.
2007 Tahoe Q4 w/ 4.3L engine on a Tahoe trailer. Minn Kota Trolling motor installed with 2 batteries on rear to the left of the engine battery.
Issue: No matter how we load the boat, the bow moves to the left to where the bow almost comes off the roller. Bow moves about 2".
Tried: -Tightening bow strap tight to almost banjo tight
- Checking to see if bunks are square (they seem ok)
- Loading slightly off center toward low side (some success) about 1"
- Checked leaf suspension to ensure they are even side to side (both seem fine)
- Adjusted stern safety straps to ensure they are tighter on high side. (low is 36" and high is 37" from ground to trim line on rear measuring point)
I am at a loss for what could be causing this. Dealer said to replace the leaf suspension but it seems fine with no sag or access bounce. Someone said Tahoe's, since they have long trailers, is to put a small ratchet strap on bow ring straight down in addition to winch strap on trailer to prevent lifting on bumps.
It is causing damage to gel coat and I will be getting a stainless bow guard installed but I need this boat movement issue resolved. Has anyone run into this issue? What's the best way of checking bunks for squareness? I measured from end corner to trailer fram edge.
