Greetings! First post even though I signed up in 2023.
I have a couple of questions:
1. Have a '99 Volvo Penta 5.0GL with I believe a fuel delivery issue; when searching the forum I see the 4.3GL threads....do the two engines use the same fuel systesms (i.e. if I read the 4.3GL posts - is it applicable to me on the component level??)
2. When should the fuel relay be energized, when the ignition is turned "on" (Should it engage to prime the pump? When I turn my switch to "on" the relay does not engage the contact. When I remove the relay and check the voltage I get 2 volts across the wires when the key is "on". I am trying to understand when the relay should engage. (consequently - I did jump the pump at it does run).
3. Lastly. I am struggling to find a schematic for the 1999 Volvo Penta 5.0GL fuel delivery system or really a good overall manual. I see on ebay, online, etc... and am willing to pay but not sure exactly what is worth the money- any advice appreciated.
