Hi, I am having the same trouble with the same engine, a Johnson cd-12 5.5 hp. It ran last week, but, only on one cylinder. I pulled the fw and the coils were cracked and disintegrating. I replaced the coils, but I was not sure which was the ground so I tried it both ways. No luck. Today I changed the condensers, and gapped the points. Still no luck. Is there something in the throttle which shorts the ignition when the throttle is turned to stop? Could there be something else which is shorting the system? Odd that it ran last week on one cylinder and gets no spark after a coil change.
Thanks, Leslie
Thanks, Leslie
