Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
- Oct 15, 2019
- 651
It was cool one morning so I slapped on a coat of paste wax to make her shiny.
Then I got started on the trim tabs. I went with Bennett SLT-10 self-leveling tabs.
Installation would have been easy if it weren't for a few things like a transom with a lot of angle, two large protrusions and trailer bunks that stuck out past the transom.
The first thing I needed to do was remove the tie-down straps and trim back the bunks. To keep from hitting the hull with the oscillating saw, I used an engine hoist to lift one side at a time to create a gap. Worked like a charm.
Cut off and re-wrapped.
With the hinge installed, I used a straight edge to set the actuators. They come with a pin in place to set them in the correct part of the stroke. They are not bottomed out. They actually allow a bit of upward travel, but mostly downward.
Installed, but still pinned. I had to position them inward from the ideal location due to clearance. These were the shortest actuators they offer. Still within the range they give, though.
