wellcraftpower
- Jun 29, 2022
- 41
the front cover on the pump has the johnson part numberHow can i figure out that part number. been trying for awhile
I found it. New one on way. thanks for your help.the front cover on the pump has the johnson part number
My marine mechanic with 40 years in the business told me to run it. Replace impeller.On a side note, one of our customers services his boat himself had an overheat issue, he had tried the clear hose trick, cleaned the ps cooler, thermostat, checked all fittings for leaks. then he had us looking at it. I did all the stuff he had done also. The last thing I told him was possibly the housing surface might be wore enough to cause the issue. He installed a new pump and the issue went away. His pump didn’t look as bad as yours but wear showed its ugly head.
That may or may not work. Hope for the best. Around here on Lake Superior, it doesn’t take long to get miles away from the nearest ramp or shoreline. Having a dependable boat is rather important.My marine mechanic with 40 years in the business told me to run it. Replace impeller.
great web sight. thanks for the information.You can buy the end plate from raw pumps.com.
