The 3 cylinder 650 and 700 ( 72 to 1980's ) were crossflow ( direct charge ) as Mercury called it.----No reason for a crossflow or loop charge to be hard to start!
Well I had the last 1988 (year built, sold as a '89 model) 115 I6, Direct Charged "Tower of Power" on my new 1989 Ranger Bass Boat. Absolutely one of the finest engines I ever owned. The DC engine had the domed piston like the CF, unlike the Loopers, but had a hole added to the side of the piston unlike the CF. Apparently that was a better entry point for fuel and made the engine efficiency more like the loopers rather than the gas loving CFs.....I think OMC still had the patent on Loop Charging causing Merc to opt for something else to improve fuel efficiency. I guess when the patent expired Merc could build their own Loopers. My 2002 115 4 cylinder was a looper.
I don't know all the details of the differences in the designs of the 3 engine types but there was absolutely nothing wrong with that DC engine. On my first outing, I was up at 55 MPH on my way on up when the Ranger started "chine walking".....scared me and shut her down. Was running a 24P Laser the dealer installed......didn't check the RPMs but they had to be low at that speed with a 24 prop on a 115 with a 2:1 gear ratio. Traded the prop in for a 19 or 21, forget which, and it would sit on 6k, kissing 50, and sing all day. You could trim it out till the prop was partially airborne...RPMs increased while the speed started falling off and hear the engine singing and the prop blades humming as they beat the water. Great sport.
This was my first experience with a "pad" boat and that was a new experience. I never had a boat come up out of the water like that and ride high and dry.
Being that the Laser (original design) was ported, (as is the Laser II of later years) you could hammer down in the hole shot, engine trim centered, get on plane fast and coming on up in speed as you were trimming on out, when the new water would seal off the ports, it was like shifting gears.....the boat would lurch forward with the new bite the prop had with the water......great sport. The other neat thing was that the same prop that got me 50 MPH also could pull me up on a Slalom ski without blinking with the ports doing their thing.
