Paradise pontoon
- Jun 27, 2023
- 63
Have 150 Johnson 1984. Runs great and ildes fine for a few seconds then dies. Rebuilt carbs. Have removed oil injection system so running mixed fuel. Run great last couple of years until carbs gummed up. But never really idle very well back then either. New fuel lines fuel filters. New primer bulb. Running electric fuel pump seems to pumping good. Even pulled the pickup tube from fuel tank and checked it good shape no leaks. So tell me when you mix fuel on a system that use not be was oil injection would you need to change idle orifices on carb to larger ? Ok find it has 33 idle jets in my carbs. Johnson offers a 34 jet only the 33 are unavailable Thinking about trying those the 34
Thanks
Mike
Thanks
Mike
