Hi.Post #3 said your spark gap tester shows a reddish glow ? BAD. Should be white or blue very thin arc in air. Testing arcs with no load on the prop can be useless.
Have you adjusted the carburetor float correctly ? There are 2 dimensions
Doesn't sound nuts...sounds electrical. Though could also be that the carb is fueling differently because of the angle. Any change when hitting a wake?Hi.
The sparks are blue and white and strong. Once in a while, I see a yellow one.
The carburetor float height and float drop adjusted to exact mm listed in the Mercruiser service manual, with no effect to this situation.
Rebuilding the carburetor actually did nothing to make things better, other than some peace of mind on that side of the engine.
I just received the M16x1.5 T-Adapter to measure the fuel pressure at idle and at high throttle, so I will test that in a few hours and post the results with video here.
One last thing that I never mentioned, and maybe because this sounds crazy, is that I noticed that when driving in the speed zone at a local lake at WOT, the engine would "open-up", and run fast as expected (RPM>3200) when making a medium-to-sharp left turn!
If I went to slow down, or if I shut it off, I could not get back to the higher RPM's though.
That led me to think that it might be a sticking throttle or shift cable, or exhaust valve, or something that by moving the throttle lever and cables back and forth, or when that left sided pressure was applied, or right side pressure of that component was relieved, then something "opened up" or got "unstuck", and returned to motor spec, and the motor responded with normal operating parameters leading to expected throttle response.
I could not re-create this phenomenon every time, but it was happening about 1/2 the time.
I should mention that this speed zone runs counter-clockwise, so I didn't get a chance to test a hard right turn at WOT yet.
I know... it sounds nuts.
I think when it doesnt restart take a spark gap tester see if you have spark if you do dribble some gas down the carb , if it restarts then you are missing gas. Just gotta figure out if its spark or fuel. Hard to tell form the keyboard but if yo have good spark and timing is right it should fire if you dribble gas down unless it flooded. if flooded you open throttle wide to clear it just be ready to pull it back if it catches...Alright, I did a test run tonight with the fuel pressure gauge inline.
I was reading 4.5PSI at idle and 4.2PSI at 2500RPM.
Tried using a hand-held tachometer to validate the dash tachometer, was not working, will try that again later.
The motor started up well into this run.
Please take a look at the video and let me know what you think.
You can definitely hear the sucking sound of the TKS, as the engine was cold just before this video.
Right after this run, I tried to restart it just as before, and it would not restart, after two tries, I called it a night. Thanks,
Hi, There is always spark to all 4 cylinders. I already did the spark gap test on all 4 cylinders. Timing was tested a month ago and it is correct. I never replaced the ignition coil because the consensus here was, - it's all or none. Are you saying to pour gas into the carburetor when it does not start? Thanks.I think when it doesnt restart take a spark gap tester see if you have spark if you do dribble some gas down the carb , if it restarts then you are missing gas. Just gotta figure out if its spark or fuel. Hard to tell form the keyboard but if yo have good spark and timing is right it should fire if you dribble gas down unless it flooded. if flooded you open throttle wide to clear it just be ready to pull it back if it catches...
Hello, The TKS Sucking sound stops after a few minutes.After the run did the loud sucking sound stop?
Looking down the carb right after turning motor off, was there any fuel dripping?
Hi, I did unplug and re-plug in each wire while running and noticed the same 200-300RPM drop on the tachometer. What else could I do to test for mis-fires? Please watch the video and let me know if you can hear any. Thanks.Also, have you wiggle tested the connections? Just grab some wires and see if anything changes when you shake em...
Yes I know you had spark , but when it wont run verify it again to determine why it went from running to not running.Hi, There is always spark to all 4 cylinders. I already did the spark gap test on all 4 cylinders. Timing was tested a month ago and it is correct. I never replaced the ignition coil. Are you saying to pour gas into the carburetor when it does not start? Thanks.
I'm talking about all connections everywhere, not just the plug wires. I already mentioned how to test for misfires under load. At 3k rpm you might not hear much. your fuel pressure sounds fine. I'm also in the minority here where sometimes it is the coil.Hi, I did unplug and re-plug in each wire while running and noticed the same 200-300RPM drop on the tachometer. What else could I do to test for mis-fires? Please watch the video and let me know if you can hear any. Thanks.
Your fuel pressure is good so this is no longer part of the problemHello, The TKS Sucking sound stops after a few minutes.
I'll have to take off the flame arrestor and check for gas dripping after turning off the motor.
There seems to be about 4PSI in the fuel line at all times, according to the inline pressure gauge that I installed.
If 4.0 PSI is my baseline inline fuel pressure while not running, and running at idle is 4.5 PSI, and running at 2500 RPM goes to 4.3 PSI, - does that sound like enough gasoline would be reaching the carburetor inlet if I bump it to 3000 RPM when the boat is on the water? I does that when on muffs. Would the fuel pressure inline from the pump to the carburetor change when the motor is under a real load on the water compared to running on muffs?
Thanks.
Thank you for all the insight and analysis into this.Knowing the cap, rotor, points all good, he replaced the coil and was fixed.
Georgio, you have really stuck to this, and I admire your tenacity. This is a head scratcher and now there are two issues, perhaps unrelated: unable to get to max RPM under load and difficulty restarting. And from watching the video it appears there is a 3rd issue that may be unrelated to the others > the engine seems to stumble, especially at the end when you came down off the high RPM (about 1:45). If that is not a good option for you then suggest replacing the coil.
The white dot I saw when the engine was stopped was right in the middle.
Please keep trying and posting > this is fixable!
Hi Guys,Agree does not appear to be contaminated fuel
You are doing all the right things (pulling on wires, etc., etc.)
I am still hung up on the restricted exhaust. I know you were reluctant to pull the valve cover (post #30) but you are clearly capable IMO.
The only other thing I can think of is the engine coupler, but you would be smelling that (burning rubber)
So, I am running out of options > coil which can be tested as above or restricted exhaust is all I got.
I wouldn't mess around with a sticking cable that wont allow it to return to idle. This is especially true for an alpha drive that requires a shift interrupt to get out of gear, and may not work at higher rpm.Hi Guys,
I ended up replacing the ignition coil, since it was just two bolts, easy to get to, and not all that expensive. The motor fired right up, as it did before, ran it for two minutes at idle, bumped the throttle up to 2K RPM's and back down. It might have been slightly smoother than before at idle, but no real difference. Since I can't test it out under load just yet. I will look at those other things. I don't smell any burnt rubber. I'll look into the engine flapper, and the valve cover.
One thing I noticed, was that from 2K RPM to idle, the throttle cable seemed to stick when I moved the throttle lever back to N. I went over to the carburetor linkage and forced the linkage back manually, and the idle returned to 800RPM, where it was before.
It seems like it's not returning to the starting point, and leaving the idle to run too high. I lubricated it well a month ago when I was suspecting a sticking throttle cable. Let me know what else I can try . Thank you... George
