Is this engine oil good?
Rivergator
I came across what I consider a great substitute engine oil that seems to meet all the Mercruiser requirements and is reasonably priced at $36.94 for a 5 quart jug. That is enough to do a 4.3 ltr. engine including filter. I's called Triax Marine Ultra, is fully synthetic and I saw it on Amazon. It even includes shipping. What do you think?
alldodge
Look at the back of the bottle and read the API certification label. Think it should be SJ
Rivergator
Quicksilver so conveniently does not disclose any certification data on their oils other than FC-W. Quicksilver is at best a blend. I believe Mercury specifies a fully synthetic oil. The rating on Triax is NMMA, FC-W, API SM, JASO MA. I think that's better than OEM but I don't know what all of that means
Lou C
No one can really say. If you run it do a Blackstone oil analysis and then you’ll know. I’ve had good results with both the conventional Merc 25/40 & syn blend 25/50. I do an oil analysis at the end of each season.
paulswagelock
Triax might be ok oil. The thing is, they mislead with certifications. Their oil is not NMMA certified, that is easy to look up.
dingbat
Should be able OK to use on those 20 hour, end of season oil changes.
jlh3rd
Ensign
eh.....fwiw.
Rivergator
The way I look at it, this this oil is most likely as good as any in that category, if not better. If you can't trust the label, well then I'll give up or go crazy. I figured I am not gonna worry about. And the price is good too.
dingbat
But the label says it is. Do you really think they risk being sued?
Deceptive marketing…
They list three specifications, but find it interesting they don’t claim to be “certified” to any of the standards nor do they claim to “meet” any of the specifications.
Lou C
Anything sold only on Amazon that’s engine related is immediately suspect to me. So they put the specs but don’t say they meet or exceed them unless that’s on their website. There are a number of alternatives you can find the Merc/Quicksilver oil anywhere really, or you can use a 20/50 from the auto parts store which will not break down viscosity in marine use….
dingbat
Digging into their website, their API SN certification number is posted.
The reference to NMMA FC-W is different......
From the data sheet for marine oils.....
SPECIFICATIONS
API SN, SL
NMMA FC-W
In small text below........
* If a specification is listed above, TRIAX LLC guarantees the product meets, exceeds that specification or is safe to use in equipment requiring that application, and is therefore covered by our product warrant.
*All trademarked names are the property of their respective owners and may be registered marks in some countries. No affiliation or endorsement claim, express or implied, is made by their use, which is strictly to guide consumers as to the application of TRIAX products and convey compatibility or lack thereof
airshot
Is the gamble of damaging your boat engine worth saving 10/20 bucks ? Never understood trying to save a few bucks, gambling on a 5K or more boat engine !
paulswagelock
The label specifically does not say it is. Just says it meets or exceeds. The final say is the nmma website which lists all oils certified, and this is not. That alone is the reason to not use it. Deceptive marketing specifically to lure consumers.
