Mercruiser 260 350v8 choke spring? Different clocked positions
sdowney717
I see a lot of potential ones to buy.
They can have the rod eyelet clocked all over the place, which one is right one to get?
Carb is the Quadrajet, and the attaching screw rusted and snapped that holds choke thermostat on the intake.
Has to be drilled and tapped, anyone done this?
example 1
NOS GM Part # 3989060 1970 Corvette 454 1971 Corvette Chevrolet 350 Choke Therm | eBay
example 2
Carburetor Choke Thermostat Walker Products 102-1002 | eBay
example 3
Carburetor Choke Thermostat Standard CV204 | eBay
example 4
71464A01 Mercruiser Marine Choke Thermostat Rochester Carburetors w /Stove Choke | eBay
Boats don't need a choke if you live where the temperature is consistent within a 30 degree window year round
However yes, the electric choke conversion is fairly inexpensive
alldodge
I wouldn't worry about which one to use because the choke rod is how it's adjusted.
Use a center punch and make sure it's dead center, drill slow and you bit should be smaller than threads. This way you might be able to re-tap it. Use heat to help drilling. Best method is remove the manifold and take to a machine shop because they know how to do it
So far as switching to electric choke, look for a choke for your model Q-jet and make sure it has all the items to remove old and install new
Lou C
There is an electric choke kit, I think Mike's Carburators and others sold them, keep in mind you want a 12V source that's powered only when the engine is running, if it is powered when you switch on the ignition the choke will come off too soon. Also, an electric choke is more properly called an electric un-choke, because if it's not powered constantly it will close and your mixture will be way too rich.
Those old style divorced chokes do work but on a boat the issue is this, they were designed for cars that ran at 195-200*, not 140 or 160. So they tend to open way slower than an electric. I've had one all these years with this boat (23 years) and what I have found is this, in order to get it to open when the engine warms up (in my case 160*) you have to set it leaner than you would in a car, so that means it won't close all the way with a cold engine. But, if the engine is in good tune it doesn't matter. Set like that, I have found these old-style chokes to work well enough. Personally, I'd like full manual control of the choke, because the beginning and end of our boating season can be cold ( 45-50*) but haven't found one with a long enough cable yet, lol!
sdowney717
I also have a 1970 Eggharbor which used to have 4GC carbs with manual choke cables. They were really long hard red plastic outside with a steel copper plated hard pull-push wire and chrome knobs. When I went to 4MV Quads, It then had electric chokes. I was happy to go with automatic chokes and newer style carbs. Those manual cables were like 8 to 10 feet long or so.
sdowney717
have drilled out bigger bolts and tapped new or repaired existing threads with taps on larger sizes. This one is pretty small. I suppose may have been 8-24 originally. May end up a #10 screw.
Just have to see how it works out. I also think a SS screw and antiseize should be used
Would drilling a hole and JB weld gluing in a SS rod from a long bolt work?
That stuff is supposedly good for high heat
sdowney717
I repaired the shape of the spring, and it works. With heat it moves up. when cools moves back into this position, and that position matches the other Mercruiser part pics online.
Lou C
Simple and it works! Just make sure it opens all the way up. I found that when I tried a 140* stat, my engine took forever to warm up so I went back to the 160* I have always used even in salt water.
sdowney717
Got it working today. Started with a 1/8" stepped drill bit, then a .151 diameter cobalt drill bit.
It found the hole.
Carefully used a 10-24 tap, you know back and forth delicately.
The new SS screw goes in perfect.
I did not have a bottoming tap, so used a 1/2" machine screw instead of 5/8".
I could have gone with a 5/8 SS screw if I had a bottoming tap, but the 1/2 inch long screw holds it fine.
Outside temps are 65, choke closed, engine warmed up and choke fully open, so it is all good now.
Lou C
It found the hole.
Very good work a well adjusted divorced choke actually works fine as long as your engine reaches operating temp. the choke spring gets heated by the exhaust cross over passage in the intake manifold. The only time I have had issues with this is when a bit of rust or sand holds the thermostat open & then the engine won’t get over 120* unless you run it up on plane to dislodge whatever is keeping the stat from closing all the way. An electric choke doesn’t have this issue because it will open regardless of engine temp as long as it’s getting power…
