Cruiser comparison
If these are sterndrive boats, the other factor is Merc or Volvo and if you choose Volvo, can you find service? Sea Ray, I believe is all Merc, but I think F/W sold many boats with Volvo power, don't know about Formula.
I'm three seasons into my first V-P, which is a 1998. Zero repairs, just self maintained with fluids, lube and filters. Shop that handled the PP inspection didn't raise any concerns about Volvo being a challenge on parts and service. They work on them as a staple of their existence. Please expand thoughts on how Volvo would be less desirable than Mercruiser? Having owned and operated many Mercs, I'm more comfortable with them. But I love my DuoProp so far.
Pmt133
My area has good dealer service for both, the Volvo parts can be more difficult to get where merc is typically on the shelf for the more oddball things. Finding a sevice center for volvo used to be more difficult and I can say they are more expensive to diy certain things. But in 2025 I don't think its an issue. Its more quality of the dealership than brand in my opinion.
Kosmofreeze
Consider how/where it's been stored - dry stored/trailer or slip. Also consider engine/drive hours (thinking VP and Mercruisers here) on the older cruisers. I see some 20+ year old dry-stored boats with 400-500 hours (just broken in?). Compare that with a 10 year old boat with 1000+ hours (worn out?) that spent most of its life in a slip. I submit that when general maintenance and condition are equal, the value proposition for an older dry stored boat is on par with a similar model that is 10-15 years newer that "lived" in a slip.
Lou C
The one you have is a good bit simpler than later models. Some of the issues with Volvo are parts prices (really excessive for certain things) and availability. Also, to me putting the trim pump in the transom shield OUTSIDE the boat in the water was a major mistake, vs the previous design, this started with the model that followed the SX (SX-A). The Ocean Series Drive (Composite) was a disaster that they walked away from, with problems with failed bellows and cracking transom mounts etc.
They do things I really dislike and force you to buy new complete components when they could be rebuilt and can be rebuilt with Merc's and even old OMC Cobras.
Example, steering actuators (commonly leak on the older models), they say hand over $1,000 for a new one, meanwhile some enterprising folks have figured out how to replace certain seals to repair it
Trim cylinders, same thing, I was able to rebuild 2 OMC Cobra trim cylinders for the cost of 2 $55 rebuild kits and about 3 hrs of my time.
Oh and that trim pump in the transom mount? It's over 2 grand.
Watch out for NLA parts for their EFI and electronic ignition parts. I have seen people have to go out and buy a cast iron 4bbl intake, an Edelbrock or Holley carb and go from an un-repairable EFI system due to no parts, back to a simpler carb. They used a Prestolite BDI system for while that you can't get modules for either.
I think service where I am is widely available for both, but I would check what year the drives are on the boat that has VPs that you might be interested in and then see how easy it is to get parts you might need.
As a general thing, depending on the age of these boats, I would not want any of them, if they have cat converter exhaust, this has added a new modern car style headache in terms of check engine lights (O2 sensors are not meant for wet exhaust) and if you have to replace the manifolds or the catalyst, the prices will stun you. Someone I know had to replace one on a 4.3 Mercruiser and the parts price was about $4500. I have seen prices for both sides of a Volvo 4.3 exceeding $6000. If I bought any more I/O boats they would have to be old enough that I could avoid that nonsense.
cyclops222
Volvo always has sold itself as....... The elitist boaters equipment.
I think they are world famous for spraying black PAINT inside of the fuel filters a while back.
redneck joe
Pumps, which then clogged filters. Cause when ethanol came about.
volvo pump paint came from the pump heat exchanger vendor that went to the tier 2 fuel system supplier for assembly. (same tier 2 supplier base that is used by other boat engine OEMs). its actually powdercoat and wasnt an issue for many years until E10 was used.
how is any of that relevant to the question on the hulls the OP asked?
Nice summation. Seems I've been fortunate so far. I also lucked out in getting a highly maintained, low hour 25 year-old boat. Guess I should prepare for unpleasantries in the future. I know how to handle most repair tasks on a Mercruiser, short of what's revealed by splitting the drive case open.
tpenfield
Of course that would be great. Most sellers want a signed agreement before sea trial. I don't know how to guarantee rough seas for sea trial.
It is actually better to have reasonably clam seas for the sea trials as the surveyor will want to run the boat at WOT at some point to get the maximum RPM and speed. Check engine temperatures with an IR thermometer, etc. All these things are better to do in calmer conditions.
During the sea trial of my current boat, I was surprised to see the mechanic checking the engines while we were underway. (it was choppy that day, but not too bad)
Your best bet for rough water handling information may be to join the Owner's Group forum of the three boats and ask owner's.
Although, if I were me, I'd be expecting the SeaRay to be the better boat in the chop, based on the hull deadrise and weight.
cyclops222
Boats are sold with cracks that have split the hull lengthwise. Nice weather ? The bilge pump keeps the boat afloat.
3' to 4 ' waves ?
Great advice
That is great advice. How was your experience with the marine survey? Was it thorough? Did you have a mechanic come out with you separately? How much did it cost for the mechanicals survey?
tpenfield
I've had surveys done on all 3 of the power boats that I bought over the years. I try to look for surveyors who have a partnership with a marine mechanic, as that makes the process easier. Basically getting it all done at once.
I usually search through boating forums for surveyors who have been recommended by others. Usually your boat insurance will want a copy of the survey to bind coverage.
A survey (& mechanical inspection) will probably cost around $1,500 - $2,000 total.
