- Mar 8, 2009
- 44,045
Last time my son called about the car not starting it was pretty simple. Did a couple test and found fuel pump was not running, so new pump and it's up and running
This time so far not as simple. I'm driving up tomorrow with tools and see if I can figure it out, bringing scanner.
Testing so far
Sprayed carb/choke cleaner into the intake and it fired right up and died once that was burned off
Tested relay and it's good but replaced anyway.
Jumped relay to bypass and still would not run, pump is not running
Fuel pump relay pin 30 has 12V full time, pin 85 gets power when key turns ON but not started
The pump receives ground from PCM so I'm thinking it's either bad wiring or PCM issue.
Testing so far
