Having Hot Start issues
Centella
Volvo Penta 5.7 Gxi-F always starts perfect when cold, but when it gets warmed up, you need to prime throttle (no need full open, 1/4 may be enough)
It Starts again fine if it sits for maybe 2-3 hours after running (requiring longer in summer time).
idle RPM are stable around 700 RPM.
Have no DTCs active and ECU triggers them whenever you disconnect a sensor e,g ECT.
Replaced thermostat, ECT, IAC, TP, MAP, Spark plugs, Ignition coil, FPR, Fuel injectors...
Fuel pressure is correct and engine performance as well, it reaches 30 knots easily at 4200 RPM, didn' t go further though it still has some RPM there.
Any thoughts on what might be happening ?
alldodge
Welcome, looks like your using a parts cannon on the motor. Replace everything and you still have a problem. Replacing parts can add to and mask what is really happening. Must say you must have plenty of money to throw at it
What is motor serial number?
What was your fuel pressure readings when it would and would not start?
What is the MAP, ECT, TPS and IAC when cold and when it won't start?
What scanner are you using?
Did you replace parts with OEM of aftermarket?
Mc Tool
Is that really a problem tho ? I have had motors that did like a wiff of throttle to start hot .
Centella
I found BOSCH original equivalences for fuel injectors, MAP and FPR.
HiWard
Do you have a part number for the Bosch replacement injectors?
I've occasionally had hot start problems on my 5.7 GXi-HF and when it finally starts there's a smell of fuel from the exhaust. I suspected leaky injectors, so I cleaned them and have not had major issues since.
Centella
Apologies for delayed answer :( , BOSCH part number for the injectors is 0 280 156 081, they come in original BOSCH package, made in same Brazil factory as the Volvoones but at almost 10 % of the cost in comparison. It is like you buy 8 BOSCH for the prize of 1 Volvo and can have some drink to cheer included :)
alldodge
Need a scanner
Going to need some actual readings and measurements
Is fuel pressure between 50-60 psi from idle to WOT?
Use a Noid light to see if injectors are turning on/off when cranking/running and that they don't stay on with motor off and key on
Centella
Need a scanner
I am not a mechanic but I have checked fuel pressure and assure it is pretty correct, and once it has started it runs perfect.
Good idea the NOID lamps, never heard about them :) , any reference in particular for these injectors ?
alldodge
Search noid light and it will come up
It's an LED which provides a light to advise if the injector is firing. Can also be done with a voltmeter if motor is off but will not work when running.
You have a motor which in most all cases we will not be able to determine faults without something that can read faults from the ECM, and see just what the ECM is seeing.
Using a voltmeter to get readings from TPS, MAP and others can help. If all I can get is things are fine is not enough for me
rolmops
Crazy question here. before you turn off the engine do you let it idle a bit to allow the temperature to go down a bit , or do you shut it off right away?
Centella
I let it idle a bit while e.g anchoring or docking. I will get those noid lamps and see the result but I will take some time since it is winter tome here and boat in 100 miles from my place, only on weekends if good weather I might go to the marina.
I was thinking also about a possible failure on Injectors relay, perhaps it stays blocked "always closed" , I will also check them and perhaps replace since not too much expensive
alldodge
No relays on injectors
12V is applied to one side when key is turned ON
Other side of injector goes to ECM and it applies a ground when to turn it ON
Centella
Well, I would say that according to the attached engine schema drawing from the onboard EFI diagnostics manual, I understand that Relay #19 is who closes the circuit to ground...
  • wiring harness.pdf
