Kicker Motor
GUS 79
I’m looking for a 9.9HP auxiliary outboard for my 19’ fiberglass REGAL open bow. That’s so I don’t have to keep using my 4.3L for trolling. Merc. - Yamaha - Honda - other. 25” shaft no used one’s out there have to purchase brand new 👏👏
saltchuckmatt
Well any 80's JohnnyRude 8 HP would work just fine for that setup unless your in the ocean and it would fish just fine there two, but...if you have to buy new and you want the 9.9 then I'd say Merc is the way to go.
American, new and matches you big motor.
Should be an easy pick.
Many 25" motors available.-----Location is everything.----Know of a 25" 8 HP now used on a 19' boat with great success.----Extension kits may be available.----New motors use up a lot of beer tokens.
redneck joe
The older 9.9 johnnyrudes were also a 15. Hanging over the back of a boat trying to pull start ain't fun, get an electric start
tphoyt
What’s your location? That’s probably one of the most common smaller used outboards in my area.
airshot
What about using a trolling motor mount that raises and lowers ? Used one for years on my 22' Islander with just a standard long shaft. When raised the entire lower unit was out of the water, flip a lever and it dropped into trolling pisition, locked into straight position, could easily steer with the out drive as a rudder. You can buy new if you want, lots of two stroke motors for sale in my area, gotta shop long and hard to find a nice one, but they are out there.
jimmbo
Nothing like having to carry a Portable Tank along if it is a 2 stroke. Maybe with a 4 Stroke Kicker, you could tap into the Boats Fuel line
saltchuckmatt
Welcome to the future....at least in the smog areas....live in the woods, your choice.
rolmops
Isn't the 9.9 Merc made by Tohatsu in Korea?
airshot
My little kicker runs about 8 hrs ( all day) on a gallon of gas. Plenty of places for a one gallon fuel can. Better than the added weight and expense of a new four stroke, at least for me.
Crosbyman
So...does your combo become a "Mercrude".... lol...
Well maybe......
but just in case anyone is offended I have a Evinrude back - up ! ...a $50 solution I picked up years ago. it just drinks a bit more but purrs all-day long .
if the Evinrude dies I have the 7.5hp :)
airshot
Must be a 2hp
Yep, a little 2.2 hp Merc, made by Tohotso. Great little motor. Always starts on 2-3 pull, even after sitting all winter. Fast idle (1/3 throttle) gets about 2 mph for trolling, just enough rpm to eliminate any vibration.
Crosbyman
well actually it is likely bigger than a 2hp !! my 75 ETEC burns .6L/h trolling so an imperial gal (160 oz) at 4.56 liters it runs 7.57 hrs ... not bad for 75hp !
.. 6.3hrs on a US gal (128 oz) :)
airshot
Wow....that sounds hard to believe, all the guys I know that have 4 strokes use more fuel than that ! Much more....
