trim cylinder issue
DFWcobalt
Apologies for resurrecting this one but having a similar issue with my VP outdrive; holds trim on the trailer just fine, but under load the prop thrust pushes her right back down.
Local shop said they couldn't find any leaks, but I can assure you that the outdrive will get pushed down. No oil visible on the drive cylinders, or under the drive when on the trailer.
I suspect the check valve in the pump. Any way to diagnose this with certainty? Would a leaky check valve just allow pressure to escape, or would/could there be a tiny leak somewhere on the pump and oil would go into the bildge?
thanks
moved your post out of an old thread
you have a leak at the cylinder. its bypassing the piston.
find a different shop, get your cylinders rebuilt or rebuild them yourself.
DFWcobalt
Thank you very much!
I'm quite sure the rebuild will be way cheaper than the local cobalt shop asking for 5k to replace the pump and both cylinders!
Lou C
I did the ones on my old Cobra a couple of years ago and as long as you can get the end cap off it’s not a hard job. Parts cost was $52 per cyl.
$75 for a rebuild kit, takes about an hour
If you don't have the pin spanner, it's about $40
DFWcobalt
Best source for rebuild kit? DP-SM
Also, how do i bleed any air from the system post-rebuild?
I use five-stare marine out of Florida
if you look at the link in my sig (near the last few pages), I go thru the rebuilding process.
take care when re-inserting the piston so you do not cut the piston seal.
BTW, that is not a "repair" that is a parts cannon firing parts swap
hydraulic piston seals last about 15-20 years. thats why hydraulic cylinders are rebuildable.
DFWcobalt
Would a pin spanner used to chuck an angle grinder work on the trim cylinder? Seems to be the right size, just not sure how much torque it has to hold to bust the end caps free
Ayuh,.... Sounds like it oughta work,......
til it don't,....
only if it fits.
this is the pin spanner that I had to use on my VP cylinders. I also had to modify it to fit around the shaft.
0703211405_resized-jpg.349131
these can work, however are more expensive than the correct ones. 1773239725242.png
these do not work that well, however I have used them. just takes 3 hands. still more expensive than the correct ones (I got mine on amazon)
I picked up one like the one on the right, then modified it like the ones in the middle.
