Far more popular today than they were just 10-15 years back for this same reason !Could use 3 sided drill bit shanks
but all my bits are standard/roundCould use 3 sided drill bit shanks
Easy enough to grind three equally spaced flats on the shank.but all my bits are standard/round
No its not !Easy enough to grind three equally spaced flats on the shank.
Cordless is handy. I have 2 with of them with 20 volt batteries I use all the time but it is the corded drill I grab when I am cutting holes in steel.Buy a new drill...go cordless this time.
Make yourself a little fixture to help you grind those flats. They don't have to be perfect to work. Small, little drill bits can be a real pain, but bigger ones are not that bad.No its not !![]()
