Missing bolt 4.3 mercruiser
tommymoore
Does anyone know the specifics on the bolt that’s directly under the distributor on a 2006 4.3 mercruiser? After a partial rebuild, it’s spraying what seems like a oil/gas mix out of the threaded bolt hole, it’s like right underneath the distributor, where the block and intake manifold meet
  • IMG_8387.mov
If it's spraying oil, it's most likely the oil port that should have the gauge sender in it
Lou C
Is this engine carbed or fuel injected? I’d be looking for fuel leaks before anything else.
