Electrical not reaching panel
Skidude17
I have a mercruiser serial number 0F598365 in a ‘96 Searay where the electrical isn’t reaching the panel. When I put a remote starter switch on the starter, I get one solid click, but the engine doesn’t turn. I have 2 batteries with fresh charges. I ran it for a couple hours today, but it died on the way back to the dock. Where should I start looking?
dingbat
Load test both batteries
Clean all four (4) battery terminals
Check that alternator is charging
Skidude17
I have tested the batteries and alternator. They’re not the problem. I wish it was that easy.
Mc Tool
A Volvo dealer ? 😁 Brushes in the starter ,solenoid.
dingbat
The remote start simply bypasses the ignition switch to trigger the start relay. The click tells us you don’t have enough current at the starter
Once you confirmed the batteries are fully charged at 12.7V, you need to check both battery cables and the solenoid with an ohm meter to confirm they are good as well.
If both those check out, you need to pull the starter to bench test.
boscoe99
On the starter itself? On the starter motor solenoid? On the starter motor relay?
Start at the starter motor itself. Jumper battery power and ground directly to the starter motor. Using suitable sized battery cables. Does the starter motor now crank the main motor? If not, it is the starter motor.
If the starter motor being powered directly cranks the motor, try applying battery power to the starter motor solenoid. Does the starter motor now crank the motor? If not, it is the solenoid. Or battery power to the solenoid. Check battery voltage at the starter motor solenoid pre and post activation of the solenoid. If the battery voltage plummets from say 12.7 volts to much lower, fix the battery cable problem.
If starter motor solenoid being powered directly causes the starter motor to crank the main motor, move back to the starter motor relay. If the relay does not provide battery power to the solenoid, and battery voltage to the relay is confirmed, fix the relay. Or wiring from the relay to the solenoid.
