Metal O-Ring appeared on alignment tool
further
image.jpgHi all,
Long time…. 2004 5.0 GXI SX-M. Getting it ready for the season and doing alignment check. When I pulled out the bar, I noticed a metal O-ring on the bar. Any insight on what this is from? I replace the gimbal bearing a few years ago…
alldodge
That's the inner spine on a lip type seal. Probably from the grease seal behind the gimbal bearing
Edit Bondo was quicker
thats a pull the gimbal bearing thing now. once the garter springs come off, you cant get them to stay on.
further
Thanks all. Got the gimbal bearing out and will replace. Having a bit of trouble pulling the seal. Any tips? Tried a 3 point seal puller but can’t get a good grip with the one I have.
alldodge
The seal can be bent up to get it out. Others may have a better idea, but take a long screw drive and smack it
