ostrichegg
- Dec 26, 2025
- 5
Hi, I have a 2005 Mercruiser 5.0L MPI (bravo 3) on a 1998 Sea Ray sundancer. Boat has run fine for the most part. Usually runs at 170 degrees all day. Took it out today and it warmed up to 170 and just sat there. Once driving, after about 2 miles I looked down and it was running just a bit warm, maybe like 175 or 180 or something. I thought, that's weird. Slowed down and eventually transitioned back to idle speed and the temp gauge shot up over 200 (still at idle speed). So I turned it right off and the temp crept back down over about 60 seconds until it hit back down around 170. And then it mostly stayed there but cooled off over a hour or two.
At some point, I figured I would just drive it back to the dock since it cooled off. Started it up and it ran just a little hot again. I was going displacement speed, maybe 8 mph. It hit about 175 degrees and then very, very slowly started creeping up to 180, 185, 190, 195 and then I hit the marina and had to slow down to 3 mph. As I did that, the temperature surged up to 215 degrees and started climbing rapidly up to 220, which is when my temp alarm went off. So I turned it back off and waited for it to cool down (let it sit about about an hour, which was so frustrating as I was only about 50 yards to the ramp!). Started back up and got to the ramp with no issues. Now it seems to be running fine on muffs. Can't get the temperature to go up past 170, although of course there isn't a load on it or anything.
What could cause this behavior? If I can't get it to overheat now, am I good or does the engine behave differently with a load (and not in "throttle only" mode)?
I'd appreciate any guidance. Thanks!
