A car engine may be capable of 280 HP.-----But it does not need near that output to move a car on a level road.----Put that car in neutral at 50 MPH and see how far it coasts.----Now try that with the boat.
Yeah ok what revs is your boat doing at 75 mph.....all day, and anyhow its not about the revs . If you over rev anything it will blow up and if you under rev anything it wont make rated power.I will add this.....go to the Eway and get on, leave your car in first gear and go cruise at 70-75 mph all day. Lets see how long your engine lasts. Then take your boat out for a cruise, but do not exceed the 2000-2500 rpm that your car normally runs at. Using this comparison, how long will your car engine last, and how enjoyable will your boat ride be ? That is comparing apples to apples......I don't buy the factory oils myself unless under warranty, but I do always use oils rated for the job/ engine I am using !
I like the penrite hpr as it has the "extra 10 " which does help maintain viscosity when hot. I started using it as when I got my Guzzi the engine had been bodgied and I was left with a big end ground to the min size ...and it was a couple of thou to small . It had good oil pressure cold but hot at idle the oil light flickered so I tried the hpr and ....yay . Coupled with the fact this thing has no oil filtration at all it get new oil every 1000 ish kms.When evaluating oils for marine use, one thing I will notice is this:
after running the boat up on plane for a while, slow down, let the boat come off plane, bring it to idle, now what is your hot oil pressure? My sense is the better oils won't let it drop down as far, for example, at cruise you might be at 55-60 psi, at hot slow idle like 20-30, but if you're seeing like 10 psi, even though it's above the minimum for a Chevy small block, it shows that some oils hold their viscosity better hot than others. The other thing is that Mercury showed the differences with corrosion resistance their oil vs others, so maybe there is something to the marine certifications.
While I have said this a few times over the years, it bears repeating, do an oil analysis at the end of each season, then for sure you will know, is the oil you are using, staying in grade. Watching wear metals, you can also see this, looking at Al, Fe, Cu etc.
You'll also know if a problem is starting to develop, by looking at contaminates, like sodium/potassium (from antifreeze, if a closed cooled engine) or just sodium (if raw water cooled in salt water). I had this even before my engine overheated back in 2013, the head gaskets were starting to leak, but the engine ran as it always did and there was no sign on the dipstick or in the oil I pumped out that salt water was starting to get in.
Yeah but a nitro drag car is producing 1300hp/litre ....on nitromethane , its not a fuel burn, its a detonation harsh enough to permanently hammer the con rods short. By the time a top fuel drag car has traveled its own length its doing over 100mph , and from the xmas tree to the end of the track the motor does only 453 revolutions (8000rpm divided by 60 seconds , times by the 3.4 seconds it takes to complete the track distance ) so yeah longevity isnt its biggest asset ,Just look around at all the high performance 4 stroke engines, dragsters, nascar, Indy type...etc...these all run at high rpm, and they all have short lives ! Bottom line is, when constantly run at high rpm, it will shorten up the life span of the engine and increase the probability of a part failure. Better quality oils do help, but won't prevent the dangers of high rpm caualties.
