MCM 7.4 oil
lconove
Hello! Seasons upon us and I have a question! Just picked up a new to me 1989 mach 1 condor in great shape. It has a 454 in it that was rebuilt 7 years ago with less than 400 hours on it. Runs great. The owner was running 5w-40 full synthetic in it. I asked him and he had called around his motor head performance friends and they said they’d switch to 5-50 synthetic. I asked some of my friends and they said leave it full synthetic if the rebuild likely had new components put in that and that they like full synthetic and at end of year switch to the 5w-50 if this oils new (it is). Engine SN:0C609422 and it starts and stays at 40-60lbs at all times.
I read that pre 1990 to run synthetic for the zinc in the oil but let me know what you guys would do especially since the rebuild?!
Thanks!
I would run Rotella T4 15w-40 diesel oil to get the zinc. Flat tappet cams need zinc
You will be changing oil every year or 50 hours anyway. Full synthetic is not needed, won't hurt, but not needed.
Gee, why not run what the OEM specifies? Likely it is Quicksilver 25/40 or some other FC-W oil. Auto multivis oil in synthetic, conventional or a blend, are generally not recommended.
I am not sure why the PO went to the gearheads, as it sounds like they are auto gearheads. Or are they at least marine gear heads?
lconove
Offshore racing gear heads lol-Or I’d feel the same way just resorting back to quicksilver. It’s what I’ve done in the past but I see a lot of people running different oils than the quick silver. I also didn’t realize you can put “diesel” oil in these but seems like that’s just to get past emissions on gas(but doesn’t apply to marine)
It's the only oil left with enough zinc
Quicksilver 20w-50 does NOT have enough zinc for a flat tappet motor
A flat tappet motor requires 1200-1500 PPM of zinc or more
Quicksilver has about 850PPM. Not enough to support a flat tappet cam
Rotella T4 15w-40 still has 1200PPM of zinc and 1100PPM of phosphorus
Know the requirements of the motor.
Original oil recommend for a 1990 MCM 7.4 was SAE 30 weight dinosaur squeezings. Not synthetic
lconove
Do you guys know what the mercury 25-50 oils zinc content is? Thinking of going this route if zinc checks out
Scott06
If you google it it comes out around 800 which is generally considered too low for flat tapped cams. You could add a zddp additive.
this is why the rotella T4 is reccomended. A lot of guys on the classic car forums I’m on use it as well For same reason.
yours would have e been speced with straight 30 wt back in the day.
Lou C
Ok first find out if the engine had flat tappets. If not & you have a roller cam no real issue with zinc. But if you have flat tappets here are some choices:
Merc/Quicksilver 25/50 syn blend, I used this and did an oil analysis & it has 1300 ppm of both Zinc & Phosphorus
Valvoline VR-1 20/50 this is about the Same as the Merc 25/50
Lucas Marine 20/50, this has a very high level of Zinc, over 2,000 ppm IIRC
You won’t find this level of zinc with Merc/QuickSilver 25/40 syn blend or conventional. Why, because they are certified as cat converter safe (most inboards or I/Os made in the last 15 years have them) and for that reason have less than 1000 ppm of both zinc & phosphorus.
Merc’s 25/50 syn blend is really for Verado outboards and they do not have cats so they can go higher on zinc & phosphorus.
On my 4.0 Jeep with flat tappets I will switch to 10/30 Valvoline VR-1. This has a bit over 1,000 ppm of both zinc & phosphorus which is what oils had when these Jeep engines were current.
Only way to know is read spec sheets or do a virgin oil analysis.
BBC didn't get roller cams until the Gen VI motors in 1996.
So the OP's 1990 Mk IV motor is a flat tappet motor
Lou C
That’s what I thought
So he’s got some good choices. The VR-1 is a bargain like half the price of the Merc 25/50 syn blend, that’s what I’d use and will probably switch to when I use up the Merc oil I have
the Rotella T4 used to be $11 a gallon. now its $15 a gallon
Rotella T5 syn blend is $19 a gallon jug
Quicksilver syn blend is $45 a gallon
VR-1 is $27 a 5-quart jug
Lucas is $39 a 5-quart jug
Penrite is $63 a 5-quart jug (because its imported to the US from Australia)
Amsoil 20W50 full synthetic is $68 a gallon
All these oils have over 1200 PPM zinc.
Lucas is claimed to have about 2X the rest.
looking at best bang for the buck.
Rotella T4, followed by T5 followed by VR-1 followed by Lucas
Lou C
Scott you forgot the Merc top of the line Merc 25/50 syn blend
it used to be $52, now it's $66, so it's up there with the Amsoil & Penrite
Lou C
Yep it's not that much money when you look at it that way. I can say after using the Merc Syn Blend 25/50 under the valve covers in my engine looks like new despite salt water use and 6 month storage outside in a damp climate. The engine is often covered with condensation to the point that any small break in the paint on the engine or exhaust rusts, but under the valve covers the cyl heads I installed 9 years ago, with the original pushrods and rocker arms, look like new. So their anti-corrosion additives, seem to work. I also scoped the cylinders with an endoscope camera and it all looked good. Seeing as how my old engine is a roller cam I can use the Merc 25/40 syn blend instead of the more expensive 25/50, because it doesn't likely need the extra zinc of the 25/50.
Scott06
Changing your oil 1/season is not going to come down to saving a few $ on cost right?
of course not but no reason to get jerked around unnecessarily and pay 2x.
I have used rotella, QS 25-40 , the merc racing 20-50 and settled on mobil 1 15-50. It seems to hold hot oil pressure on long higher rpm runs better than the rotella or QS25-40. Its half the cost of the Merc 20-50.
I agree use what is recommended but also no reason to not use something else if it is good substitute and more cost effective. Probably any of these even with lower zinc/zddp are better than the old school 30 wt it called for originally. Also given the age and hours if the engine had wear and lower oil pressure - would you not run a heavier wt oil just because it wasn't recommended?
Point being dont just swap in something else with out thinking about it. In my case I found something that works better than OEM for how I use my boat. Would I pay the $65 gal for the merc if I thought it was better - of course yes. Just no need to.
Lou C
I'd be interested just to find out what additives are included in the FCW certification for marine oils, that are not in automotive oils, it seems that you can do virgin or used oil analyses and get a lot of information but not about additives. This information is "proprietary" I guess. They don't want us to know. Not saying they don't work, but would like to know.
Its not about the cost, its about logistics
you must have a low cylinder index. at one point I was maintaining well over 110 cylinders per year. thats a fair amount of oil per year. with the current fleet down to 40 currently active, I still try to only keep 5 oils on hand. 15W40 T4 for the boat, outdoor power equipment, and the step sons car, 10w30 full synthetic for the truck and the daily whip, 5w30 euro for the wife's whip, and two types of 2-stroke oil.
and that is not getting into the plethora of gearbox lubes that must be kept on-hand
Plus I knew most of the engineers at Mercruiser from 2000 - 2020, many of which worked for me at one point or another over the years. I personally wont use quicksliver products unless I have to in an emergency. the extra cost for the label isnt worth the product since Quicksilver was Citgo per the MSDS a few years ago. not sure if Citgo is still putting it in the pretty bottle for mercury or not these days. then again, resolute brand at most farm stores is also Citgo.
depends. is the lower pressure due to a stuck PRV, bearing clearances, or other?
