juanallen78
- May 17, 2026
- 4
Hi All. Just found and joined iboats.
I hoping to find some info from the guru's.
I am from sunny South Africa. Where anything boat related comes at the cost of a house.
That said I got a fiberglass bass boat and had to rebuild it from the hull up. Got a johnson v4 crossflow 90hp on it and life was great. Until it wasn't. Long story short I had 2 pistons that I have to replace. Bores cleaned up to with in spec. I have a 140 hp engine for parts. Block was junk.
I have read a fair bit on the mods some folks do to go from 90hp to 140 is spec, and man there's quite a bit that some guys do.
I want know since she is already open is it worth lifting the port timing to that of the 140. I have the bubble back exhaust, the 140 heads and carbs. Also plan to smooth out and polish/ match all the intake and exhaust passages. The boat is 17 foot and fully loaded with gear and kids she is around 1000kg or 2200pounds. She has a worked 17 pitch prop and was running at 58 to 60 kph. About 37 miles per hour at 5000rpm. Wouldn't mind get some more ponies out of her if it won't kill reliability. I also plan to do fiber reeds. Any advise would appreciated.
