Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
do I need to replace it when it drips about once per second from the pee hole,running at idle on the hose.The motor is an 85 johnson,10 hp.Also. if it needs replacing,do I need to drain the gearcase before removal?
I would first make sure the tube is clear by blowing air into it, If that does not work then you might need a new water pump. You donot need to drain the gearcase to do this.
