imported_Warren
- Apr 7, 2003
- 261
I replaced my Water Pump and thermostat, while I was inside the lower unit I looked for corrosion and didn't see any. The water is peeing out of the hole full speed and it runs like a champ but the water is peeing pretty hot. I took it to the lake last week and for about 30 minutes the water was cool(same as the temp of the lake), I checked it again and it was hot again. Can't afford to take it in. I do have the seloc manual, someone told me that there is some kind of grommet attached to the bottom of the powerhead that may be stopping the circulation through the head. I am not sure if this is something that I should attempt myself. Does the powerhead come off in one piece?....Any help would be appreciated. By the way the old water pump impellor was in one piece and in good condition so I don't think a piece is stuck in the motor. I have also heard of hooking up the hose to the water intake tube inside the lower unit and trying to blow it out, Has anyone tried this???...Thanks in advance for any help........Warren
