I am removing the prop shaft from a 40 hp johnson (1992) and have a question..Do i have to remove the drive shaft completly or just take the nut off of the pinion gear to get the prop shaft out? I have everything else out and did not want to go any further until i found out if i had to remove the drive shaft...how about the shift linkage? do I have to remove it?<br /><br />thanks<br /><br />Chad
