have a lot of hesitation out of the hole. checked compression. good. checked lean/rich mixture. when adjusting screws top carb. does not show any change with screw all the way in or out. tried using a dry rag in the air intake of each carb one at a time while engine running to see if engine would stall. bottom carb. this made no difference. think i have a vaccum leak bottom carb but don't know why the lean/rich screw adjustment made no difference top carb.
