Re: 60 hp Tracker Mercury overheat horn
When the horn is sounding remove the cover & touch the head between the plugs it should be hot but not hot enough to burn or make you pull your hand away.If its too hot.Check thermostat & poppet valve & flush block while you have the thermostat out.It wouldnt hurt to rebuild the water pump as well just to be sure.It may just be a short in the wiring or a faulty sender,if the head temp is ok.
