Re: mercury 1150 troubles????
Ok, new troubles, not completely sure this wasnt the original problem.. Now the motor (77 merc 1150 I6) is acting real weird. It has a mind of its own. OK the following symptoms are never pinpointed to an exact time frame. (happens when hot or cold.) It sometimes has a ton of power and will hit wot @ 5200 rpm no problem,((Woohooo, the power... its there.... 115 on a 1552 flatbottom)LOL... and sometimes bogging and wot is 4000 rpm, wont hardly plane, and is really struggling, then BAM it kicks in power again, then ughhhhh is loses is again... off on off on.. grrrrrrrrrrr... make up your mind old merc.... Also it barely pees at an idle, (i took the hose off and blew it out, also i covered the 2 exhaust holes mide motor, and blew through the hose and it bubbles under the jet so its not blocked.. it seems to be running hot, the pee is steaming???? and I cant hold my hand to the block for more than a few seconds, OOOOOOOUUUUUCCHHHHH... So i am sure I need a water pump kit. Where can i find a diagram on how to replace it myself. And does the power problem sound like the power pack going out???? Where is the best place to buy merc parts online??? <br />THANKS EVERYONE, <br />BRIAN (Missouri) <br /><br />P.S. I forgot who posted it, but thanks for the post on the trim motor, brush fix.. Brushes where sticking. took a lil emery board and cut it small enough to fit, then removed the brushes and smoothed down the rusty walls and put the brushes back in, and sprayed it all down with electrial cleaner, and my trim works like brand new, no more clicking, wining.. Just straight to the point.... up and down...<br />THANKS AGAIN
