Re: mercury 1150 troubles????
A MIRACLE HAS HAPPENED, I THINK? first lets break it back down.<br /><br />PROBLEM:<br />(1977 merc 1150 I6) LOSES POWER @ WOT.<br /><br />SOLUTIONS: (trial and error)<br /><br />1. Cleaned fuel filter and checked fuel pump diaphrams. (they where fine) (no luck)<br /><br />2. Checked spark on all 6 plugs (good) and installed new plugs for the heck of it. (no luck)<br /><br />3. Found gas tank ventilation problem. (Fixed)(helped with one problem) (different problem arose) (kinda) now more like missing.<br /><br />4. Replaced water pump impellar, engine was running real hot. (pees like a race horse now) I can actually touch the power head..LoL (but didnt help the problem)<br /><br />5. Cleaned carbs. (no luck)<br /><br />6. New pump ball and fuel line to a new auxillary tank. (no luck)<br /><br />7. Taped the plug wires. (stopped the little sparks, but still no luck) <br /><br />8. Found an auto parts store that sells universal 7mm, hi-heat, double silicone, copper core wires. $20.00 WOW took a little time and patience, but saved me a hundred bucks.. (no luck)<br /><br />Took it to the lake today after the new plug wires installed. Still ran ****ty.. <br />Decided to check the plugs for spark again, and OH MY>>>>>> #3 and #5 look like the ends where welded.. It has the no gap, or true gap spark plugs, and the whole bottom was covered in what looks like metal, and I cant scrape it off... ??? Could this be metal shavings from the rings or cylinder was when this thing was running hot??? And why only on #3 and #5???? Weird!!!!<br /><br />However I replaced the 2 plugs, and she ran like a champ for like 3 hours straight then it got dark, the hole time between 3800 and 5000 rpms... I THINK ITS FIXED, I WILL TAKE IT TO THE RIVER TOMORROW AND SEE WHAT HAPPENS..<br /><br />Oh yeah, I also still have a ventilation problem with the main fuel tank ( ALL ALUMINUM TANK ) It keep sucking the new pump ball flat. It dies within like 5 minutes, then I switch back over to the plastic auxillary 6 gal. tank runs fine... Also with the aluminum tank I keep getting crap in the fuel filter, like purplish hard, i dunno almost feels like metal.. (I HEARD THAT METAL OR ALUMINUM TANKS CAUSE PROBLEMS????) <br />I'll keep ya'll posted.. Thanks again for all the support...
