Hello,<br />Just found the site today. Great site. <br />I've recently had issues with my 25hp merc...here goes..I let it sit up from May 05 til Sept 05, (I know this is not good) so I had to have the Carb rebuilt by a local boat mechanic. Just yesterday was the first time that I was able to try it out, it started right up (would not previously do this) and ran for about 15-25 seconds... then shut off, I reached down and the bulb is pretty flat, so I pump it and it starts right back up, and again repeats the above situation. So I finally just started pumping the bulb and it ran like brand new..(as long as I pumped the bulb)...So any suggestions? I was told that the fuel pump is built in the carb? I guess there is no visual check, the mechanic could have done? Next, could it be the gas line/tank? Any easy way to test this, other than purchasing a new one?<br />Thanks for any help...<br /><br />Decoy
