1987 Yamaha 70 ETHL
Fip
I have a 1987 Yamaha 70hp outboard. It will not run up under a load. The engine runs great with the boot on and will run up in speed. Once I put it in the water or a test tank it will not run up in speed. I have rebuilt the carbs and it doesn't seem to be fuel. I have run it in a test tank in speed and added fuel through the Carbs and it will not run up. The CDI checks out ok. Any ideas?
Ray Neudecker
Re: 1987 Yamaha 70 ETHL
Check compression first and check fire with a light. If both are okay, you are back to a fuel restriction.
Fip
What do you mean by check fire with a light?<br /><br />Thanks,<br />Bill
Ray Neudecker
Use a timing light on the flywheel to check for fire and timing.
Fip
Ray,<br />Thought that's what you meant. I'll give it a try.<br />Thanks, <br />Bill
