2000 yamaha 4 stroke will not start
ak_sowa
First off I stored my engine on the wrong side. I then tried to start the engine but the pull cord would not pull. I then manually moved the flywheel around to see if that was the problem (hopefully I didn't blow a seal?). I then drained the oil, pulled the cord several time to get the oil out of the cylinders, put new oil and plugs in. Tried to restart. Will not start. Not even close. I have fuel hooked up, choked, etc..I repulled the plugs and there is oil on them. Should I turn my engine on the correct side to get oil to come out the spark plug holes? How about putting gas down the cylinders then trying to start it?
rodbolt
Re: 2000 yamaha 4 stroke will not start
keep flushing, once the oil is flushed from the cyl/intake tract it will run again. yes you can flush it with gas, GASOLINE IS EXTREMLY FLAMMABLE.<br /> if you pull the start cord it comes out the plug holes. make sue the spark part of the ign is disabled.
JRJ
If you haven't, pull the plugs again. Pull the start cord a lot to expell the oil. Install another set of new plugs. Use the flooded engine procedure when you try to re-start. Good luck.
rodbolt
not knowing the HP or the model number I cannot help with any starting procedures.<br /> some of the smaller 4 strokes have a manual choke other use an auyo enrichment feature. if it has auto enrichment opening the throttle to much will result in a no start condition. once the oil is gone it will run normmaly again. this is one case I would use a bit of ether :) .
ak_sowa
6hp yamaha 2000 4 stroke with manual choke..several times i tried the ether, gas down the clyinders, and new plugs. ran for seven seconds..
rodbolt
have ya drained the fuel from the fuel bowl, not real sure how it happens but occasionally the oil drains into the carb fuel bowl. your not the first to ever do this. i get a few every year.<br />if its trying to run your on the right track.
ak_sowa
drained oil out of the carb fuel bowl and blew on the fuel line going into carb. got it to run but now it won't idle, i have to keep it reved up to keep it running. going to try draining carb fuel bowl again and changing plugs. thanks for the help..i see king salmon in my near future!
