First off I stored my engine on the wrong side. I then tried to start the engine but the pull cord would not pull. I then manually moved the flywheel around to see if that was the problem (hopefully I didn't blow a seal?). I then drained the oil, pulled the cord several time to get the oil out of the cylinders, put new oil and plugs in. Tried to restart. Will not start. Not even close. I have fuel hooked up, choked, etc..I repulled the plugs and there is oil on them. Should I turn my engine on the correct side to get oil to come out the spark plug holes? How about putting gas down the cylinders then trying to start it?
