Baylinerchuck
- Jul 29, 2016
- 2,740
So I decided to start a repair thread for my 1990 20' Chaparral bow rider. I purchased the boat in Virginia. The boat spent the vast majority of its time on Lake Anna, and only had one owner. Though the PO claimed to have taken very good care of her, there were several issues I saw right off the bat that would need addressed. Since this boat was exactly what I wanted as far as motor, design, and price, I made the purchase. I spent about 6 weeks trying to make her run right, seeking advice at times from this forum. Everything I replaced was what I would consider basic maintenance. Oil, filter, plugs, wires, distributor cap, rotor, thermostat, exhaust shutters, and retimed it. I cleaned the fuel pump, installed a new fuel filter, fuel lines and checked the tank. While cleaning the carb I found a blockage that could not be cleared. I purchased a remanufactured carb. While all this was going on I gave the trailer some attention. New tires, rebuilt the master cylinder, new brakes, bearings and seals, and new wobble rollers. The PO had the boat positioned so far back on the trailer that every time I hit a bump, the surge brakes activated. I extended the tongue a foot and pulled the boat forward, repositioning the wobble roller brackets. New LED lights, soldered and heat shrunk connections completed the trailer work. I have had the boat since early July and even thought it didn't run perfectly, we still managed to use it every weekend. Now that the motor runs strong and is reliable, and trailer is safe, it's time to begin focusing on some other things. The floor has a soft spot right in the area above the fuel tank. It's a plastic fuel tank, so I'm sure condensation has a lot to do with the floor. Stringers in that area don't look great either. There are some other wood related issues such as the backers to the port side vinyl. I'm sure I'll uncover more as I progress. I plan on using her a few more times before digging into the floor. I really want to take in some autumn scenery at Raystown Lake before I start. I'll have a few more posts of things I've already done in the coming days or weeks.
