Chaparral 2000 SL Sport floor, and more?? [SPLASHED Sept 2017]
Baylinerchuck
No Title
Did a little bit more tonight. Got the rest of the pads out of the bow, and the rest of the carpet is history. I took a lot of measurements and pictures. I'm not sure why the bow box in the center was not set up as storage. I'll be changing that as I rebuild the bow. I'm going to carefully remove these pieces so I have a good pattern for reconstruction.
Baylinerchuck
No Title
I had about an hour and some change to do some work on the Chap tonight. I wanted to use a new power tool I picked up from HF. I wasn't sure if the plunge blades would work on fiberglass. All in all the oscillating tool did well. I used it to separate the bow seat frame from the hull. This was really tricky when I restored by Capri, but this plunge cutter really did a nice job. It was slow, but precise. I wanted to keep as many of the pieces of the Chap in tact so I have good patterns to build from.
drewm3i
That wood you removed from the bow section looks good? Why not replace parts that need it only? I am shocked your deck didn't have glass over it. Every other Chap I've seen does...
Baylinerchuck
Trust me, the wood is not in good shape at all. The bench top in the bow was cracked and rotted, the pictures are deceiving due to the resolution. Even if it was in good shape I still need to remove it in order to replace the deck. And my deck was glassed at one time. I guess years of water exposure rotted the wood under it and the fiberglass just deteriorated. In the areas that were protected from exposure, the fiberglass was 3/32 thick top and bottom. I think the real issue was it wasn't sealed, and thus porous. The material I am replacing this with is fiberglassed and gel coated, both sides.
airdvr1227
Looks like you've got things well in hand. Tagging along for moral support.
Baylinerchuck
No Title
It was 79 degrees in South Central PA today. I was really kicking myself in the butt for tearing my boat apart, lol. Oh well, the damage was done....
Today I finished taking apart the bow seating structure. I used the oscillating tool to save the pieces for patterns. I got a good look at the backside of the bow hook. As you see in the picture, it will need reinforced. Seems to me it would take an awful lot of force to pull that through fiberglass.
I started removing some sections of the deck in the bow. It really slows down over the stringers. Although the deck and stringers are rotted the fiberglass still holds amazingly well. I have just about all the foam exposed on the starboard side. It's wet enough to pool water when I press on it.
I need to remove the foam on both sides of the fuel tank in order to get it out. The tank is wedged pretty tight by the stringers. I would like to try and move the thank a little farther forward. We'll see if I can do it when I do some layout.
More to come!!
Baylinerchuck
No Title
Had a couple of hours while the Admiral was feasting her eyes on The Voice to sneak into the garage and get some work done. The hardest part of this demo so far was the removal of the fuel fill hose. Sheesh that thing was adhered to the tank and fill cap!! I didn't realize this stuff had steel wire inside it.
So any way, removed the fuel fill and vent lines. Removed more of the plywood deck from the port side and started removing wet foam exposing more of the stringer.
79_banshee
Almost down to bare hull. Won't be long and you will be there. Love all the pics
52FordF2
Did I miss something? Did someone else talk about this? :confused:
Your boat is on a wobble trailer, have you shored / brace it so the rollers will not put imprints into your hull.
From the inside on my hull after tear out, I could see every keel roller imprints. I removed the keel rollers to let my hull relax before the build up. I'm on a bunk trailer though.
May want to build something to take the load off the rollers.
Baylinerchuck
Nope, you haven't missed a thing. She is still on the trailer and I haven't added any other support. There are 32 rollers under her so she's well supported. I have been checking to make sure what you describe is not occurring. When I restored my bayliner I kept it on the roller trailer with 16 rollers and had no deforming of the hull. As rotted as the Chap is, if the rollers haven't left an impression from sitting on the trailer all these years I doubt it will now. Definitely a good heads up though 52FordF2. Something to certainly keep an eye on and re support if necessary.
tpenfield
Keep in mind that once you pull the foam out of the hull chambers the rollers are more likely to cause indentations in the hull. Then when you re-foam the hull those indentations could become permanent. So, like you said, something to keep in mind and check along the way.
Baylinerchuck
No Title
I guess it's pretty easy to place wood planks between the rollers and the hull. Just to be 100%. Thanks for the advice guys. I just figured the rollers were close enough to the chines that disfiguration wouldn't occur. But, an ounce of prevention.....
If you look at past posts you'll see there is very little foam in this boat. I really did not want to put any back in. I can guess what the thoughts would be on this, but can I have difinitive reasons for the foam? Can I add a few more bulkheads instead? The material I am using to do this rebuild is glassed and gel coated on both sides. This stuff is amazing....and I get it for free!!
JASinIL2006
The amount of foam doesn't look too out of the ordinary, based on the pictures...
In addition to providing some extra buoyancy in the unfortunate event your boat capsizes, the foam really stiffen things up. When I put in my new deck, I thought it was pretty solid even before I foamed it. I was really surprised at how much more solid it was after foaming. It was really noticeable.
Foam will also make your boat quieter when you're running at speed and hitting chop.
tpenfield
+1 on the foam. Folks think that the foam is soft and pliable. It is actually very rigid and will stiffen up the boat more than a lot of things that you can do otherwise. Flotation is also a good thing to have.
Baylinerchuck
The reason I wanted to negate the foam was that I haven't been able come up with a good drainage strategy in the event water gets into those cavities again. I know that the best plan is to ensure it doesn't get in there. But what if it does? I'm thinking there is no good answer other than foam it and forget it.
79_banshee
I'm pondering the same thing. I didn't have expanding foam in the bottom of mine it was just the flotation foam 2x4s. There's no way they made it quite or stiffer. And I doubt it would of helped it float if somthing ever happened cause they was soaked. I do like the idea of putting expanding foam in it of coarse (the floatation stuff of course) to make it stiffer and quite but I don't like the idea of water getting trapped in there if it ever got in. Tuff choice man tuff choice.
