Help me set up my new edelbrock 1409
Pmt133
Master Chief Petty Officer
I set mine on the trailer but it behaved the same in the water. The service manual for TBV says to set in the water.
Rugglesworth
So fire it up, jumper wire on, take throttle connection off, adjust idle screw and then adjust throttle cable and reattach? Anything im missing and have I done it right so far?
Pmt133
Yes. That seems right. I followed this:
I would set base timing to 10-12 degrees BTDC
You set idle in the water in gear
you adjust the idle mixture screws to the point where the engine gives you the most vacuum at idle. each engine and carb are unique and need to be tuned in-situ
Rugglesworth
ok so I need a vacuum gauge for this procedure. I read on here 8 btdc was the right number but I guess 10 can't hurt. Is that a number from a factory manual or a number that's worked well for people? Thanks for your help
Rugglesworth
I should also mention while I was adjusting the timing by moving the distributor (grabbing it by the top over the wires) I was shocked. I was wearing a leather glove but definitely felt it a couple of times. Does this mean my wires are toast as well?
8 degrees keeps the motor dummy proof from someone using 85 octane fuel with water in it (detonation) and keeps reversion at bay when when the motor is installed in a sterndrive application with a lot of tail load (extended swim platform). the distributor advance of 24 degrees makes the motor happiest to pull load with a static base timing of 12 degrees. 12 + 24 = 36.
yes, or at least the boots need dielectric grease
Rugglesworth
ok thanks that makes a lot of sense. This boat does have a large built in platform but is an inboard. I have some diaelectic grease so I'll try that first
Rugglesworth
alright, she's purring at 12 degrees idling at 800 rpm cold. Put on the dielectric grease. She starts up immediately with hardly any throttle will almost start cold with no throttle. I'm going to try to dip her in the ocean this weekend to do the idle adjustment as that's what is closest to me. I don't have a vacuum gauge right now but I will get one and check the mixture again when I get it.
Scott06
I've never hooked a vacuum gauge to my boat, car for sure) I do it mostly by ear. On my 5.0 w a 1409 I find it likes it about 1.75 turns out
Rugglesworth
Yeah I did it by ear as well. Will see this weekend how she performs
You can also use an unlit propane torch vs a vac gauge.
Wave the propane torch over the carb. If the idle rises, you're currently lean. If the idle drops, your currently rich
ESGWheel
If you were getting shocked, it’s an indication of the insulation breaking down and it will only further degrade with time. Best to simply change out rotor, cap and wires and use some dialect grease on the boots for the plugs. Boating time is short and best to have a full up round in all aspects possible. So, for a couple of Benjamins better safe than stranded.
Rugglesworth
I like old school stuff like that. Ok so if the idle stays the same I'd be dialed in correct?
Rugglesworth
ok so I'm finally able to get her in the water tonight after work to do the final adjustments.
1) I believe the manuals I've seen say to set the idle in neutral but I could have read it wrong, why is in gear better?
2) what should I set idle at? 650? 750?
Thanks!
if you set it in neutral, when you put it in gear, the RPM's drop, and could snub the motor. shoot for 650 RPM in gear
Scott06
Thanks!
It’s under load idle will drop from where it is in neutral
