Keep blowing my starter solenoid up.
kd4pbs
It's because you are confusing Ohm's law with Watts law.
Do ohms law and ohms law only, see what you get. Remember, your light bulb is a linear resistor, so Watts' law doesn't apply the way you think it does.
Naah - been an EE for almost 40 years now. I'm pretty daft in my older age, but this is back-of-my-hand stuff. In a few years, God willing I live that long, I'll likely be sitting in a nursing home rattling this stuff off mindlessly to the nurse changing my diaper, not even remembering what I had for breakfast. For now, you all will be the target of the rambling ;)
A 5 watt 12VDC bulb draws .42A and a 5 watt 24VDC volt bulb draws .21A. It doesn't matter if it's a light bulb or a subspace communicator. If it runs at 12 volts DC and consumes 5 watts of electrical power, it's drawing .42 amps.
Let's throw that next monkey wrench in the ointment and deal with AC power. With everything other than DC, there is a negligible but measurable effect caused by circuit impedance on every single load. So, that 5 watt 12VAC bulb might actually draw .42000005A because of the effect the length of the conductors inside the bulb has at AC frequencies. In fact, just applying the DC power to the circuit will have some finite affect outside straight up DC theory that can be measured since it's changing the circuit from one voltage level to another. Once the circuit voltage reaches steady-state, then it's back to easy street figuring out these things.
Sorry for the thread derail! I hope the OP susses out whether it's the pilot or the main solenoid.
cyclops222
It has a Positive Temperature coefficient of resistance.
The hotter it gets higher the resistance.
kd4pbs
It's actually a positive temperature coefficient. Higher temp, higher resistance. With temp in the Y direction and resistance in the X, the graph slopes upwards NTC slopes downwards.
This is why they are rated at a certain voltage and while making light. That 5 watt bulb draws much more power before it becomes incandescent.
Grub54891
A few days ago the temperature was in the 90’s. I resisted to do a few things . Temperature does cause more heat and it takes more effort to push ah, ohm, myself to discharge my energy.
but a well oiled machine will keep plug’in away.
cyclops222
A incandescent COLD light bulb can pull 15 to 25 times MORE current when first turned on. Hard to believe but true. The reason why Mercury light switches never burned out.
I Installed them in my new how when built in 1972. I have mostly 150 and 360 watt light fixtures. 6 X 60 watt bulbs in them.
Most people change everything in a light not working. Before realizing it is a burned out light switch.
Grub54891
Changed my switches. Nope. The stupid leds still flicker unless I take out one bulb in a three light fixture. Yes I replaced all the wiring to 20 amp wiring all the way to the 100 amp panel. And put in another new fixture.
