cyclops222
- Mar 21, 2024
- 2,575
After 3 years the copper in the battery cable actually corroded away to causing intermittent slow starts.
Yes, but in something with a fixed resistance (light bulbs, poor connections) the current drawn is proportional to the voltage.You have that backwards. Higher voltage requires less current for a given power load.
Explain the me mechanism of this
My understanding is that V = I x R
update on my issue. after doing some checking with a voltmeter and test light I found that my alternator is putting out to the ignition switch 16.8 volts just off of idle on the hose. Way to high. Thinking this is what's burning up the contacts in my solenoid. Thoughts?
That is correct. And I=V/R, and R=V/I.Explain the me mechanism of this
Lou - this is basically what properly installed multi-battery systems with battery isolators do. In my Regal (5.7 Gi V-P DP-SM) I've got two batteries which are charged through a battery isolator. There's a sense line coming from the isolator that runs back to the sense terminal on the alternator. I have run the charge circuit from the alternator directly to the isolator, bypassing the round engine connector. This way, the batteries are charged regardless of the position of the battery selector switch. Running that sense wire and dedicated charge wiring even to a single battery setup works quite well. It's also smart to run a separate dedicated charging circuit from the alternator, because most of the time it's ran through the round engine connector which was never designed to handle the charging current modern alternators can produce. I've seen many of the alternator circuits on those connectors in very poor shape.Actually thinking about it the best set up might be to run the sense wire from the alt to common terminal on the battery switch since it’s closer to the batteries…
So, at 12V, our 1500-watt starter draws 125 amps of current. At 10V our 1500-watt starter draws 150 amps of current.
As long as the power load is designed for that higher voltage, you are 100% correct sir. I don't think rpatton swapped out all of his 12V accessories for 16.8V accessories thoughYou have that backwards. Higher voltage requires less current for a given power load.
You would instantly blow the filament making R = 0.0So if we put 24 volts on 12 vdc bow lights ?
Ohm's law deals with the relationships between current, voltage and resistance.We are talking working voltages in a boat. No electrical design.
I think you mean R = Infinity......You would instantly blow the filament making R = 0.0
To Solve for current (I):
I = V/R
I =24/0
I = 0.00
Let's assume you have a five (5) watt bulb rated up to 24 VDC .......
5 watts @ 12V= 1.3A
5 watts @ 24V = 0.3A
How do you decided what wire size and or fuse to use w/o applying electrical design principals?
That would actually be R=∞You would instantly blow the filament making R = 0.0
For some reason, my numbers differ greatly.Let's assume you have a five (5) watt bulb rated up to 24 VDC .......
5 watts @ 12V= 1.3A
Same general concept. But I don't remember the point of this thread anymore.For some reason, my numbers differ greatly.
I=P/V
No idea how my calculator came up with the numbers above.....lol but the answer is still the same...... Higher voltage = less currentFor some reason, my numbers differ greatly.
I=P/V
It's because you are confusing Ohm's law with Watts law.For some reason, my numbers differ greatly.
I=P/V
