nola mike
- Apr 22, 2009
- 5,764
Like the title says, I found some rocks the other day. Going to blame my inexperienced crew member, since obviously it wasn't my fault. Generally not a ton of obstacles around me, this is my first ground strike in 16 years.
One dent on one blade with a fairly small amount ground off. No significant performance/vibration issues that I can tell. I haven't tried to straighten/smooth anything.
Currently have a 21p Turning point hustler on there. Generally pleased with the performance. I've tried black max aluminum 19/21/23p on there previously. This is much better in every respect (maybe lose 1-2 mph top end vs the 23). Latest WOT with my kid the other day was 4600 rpm in smoothish but not perfect water.
If a prop repair shop even existed around me (don't think it does), doubt it would be worth repairing.
4.3L mercruiser, vortec/4 bbl carb, hull weight is about 2k (and ass heavy) with top speed of 49 on a good day.
Suggestions for something new/different? The boat is worth nothing, so don't want too much bling in a prop (think $3k rims on a '04 civic beater).
