nola mike
- Apr 22, 2009
- 5,835
nopeThat Prop has been repaired before
Bought it new from Amazon (not 3rd party). The lovely paint job is mine after repairing. Guess it could be counterfeit or misrepresentedThat Number(0522) stamped on the Hub, is likely a Repair Work Order #, and the Prop looks like it has been repainted
Heat helps when rebending aluminum....The only time I tried to bench true an aluminum prop the blade I was straightening cracked. Aluminum doesn’t like to bend and, unlike steel, has no memory of where it was.
The last time I asked a boat dealership if there was anyone in the area working on props I got 3 phone numbers to try.
If you got one you are happy with get another.I'll do some bench side truing, but the prop is only $110 new and again, I don't even know who would do it around here. The pita factor isn't worth it. Wondering if I should buy another identical prop or go with something SS/fancier, if any gains would be worth it. This prop pulled my old ass up on a slalom ski the other day with 3 aboard, definitely better than the 3 blades I'd used
