cyclops222
- Mar 21, 2024
- 3,067
I did it with the garden hose on fine spray setting in the 1957 period. Olds V 8
water or a mix of water and methanol injected into the intake has long been a solution to detonation in hi compression turbocharged engines ( Im sure the jetfire Oldsmobile turbo engine came with water /methanol injection as standard equipment .....you had to keep the reservoir full ) and if you have even seen the piston top and combustion chamber in the head of an engine that has coolant getting into the combustion chamber you would see how clean they are. If you suspect dieseling because of hot carbon deposits injecting a mist or fine spray of water into the intake will indeed clean things up well. I have seen peeps using a windscreen washer pump , and a garden mister nozzle over the carb inlet hooked up to a micro switch so as to turn on pump at or near full throttle .May I practice this on your car first?
Nah, this is actually a thing.May I practice this on your car first?
EDIT: whoops, everyone beat me to it.
I've used it within the last 10 years so the technology still works...I know it's a thing. I just haven't heard it suggested in about 30 years.
Cant say as I have noticed that but both my diesel work van (automatic .....absolute pig of a thing) and my Ducati ran noticeably better early on a cold or frosty morningHow many of us can feel a difference after driving in VERY HEAVY rain conditions ?
Yeah , funny tho that I never notice that in any car ( Im sure the o2 sensors must tell the ecu bla bla bla ) but on a carbed motorbike it shows a difference . Ironic that I wait for a nice day .... when it dont run so crisp and spend half the trip lamenting itCooler/Colder Air is Denser, thus has more O2 per, whatever unit you want to measure it by, thereby making a bit more Power.
Rainstorms often drop the Air Temp by several Degrees, and that to leads to a better feeling engine.
