‘74 Holiday restoration
Kmsp1264
bchaney
Very nice paint jobs and great pictures. I am jealous of your garage and driveway.
classiccat
"Captain" + Starmada Splash Of The Year 2020
You're flyin' Kmsp!
That header turned out really nice! Is that original/reclaimed?
Kmsp1264
All original, sanded and put on spar varnish on the header ( Mahogany) it’s a little rough on the edges but good enough. The pictures look better then it looks but again it’s good enough.
Kmsp1264
The front header is oak covered in 2 coats of spar varnish, the original header was too far gone.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
I love it when a project comes together!!!! Makes it so much easier when you get to see progress!!!
Keep up the good work
SHSU
Kmsp1264
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
​ I have the exhaust fan mounted with a hose going down to the lower 1/3 of the bilge area, where are hoses routed to on the intake clam shells? And the other exhaust clam shell?
SHSU
Doesn't look like the pictures made it
SHSU
Kmsp1264
D5BE53A5-129B-492A-AA4C-DF69582BFCEA.jpeg Glad that’s in there now I can fit the top dash piece
Kmsp1264
classiccat
windshield schmindshield...No problemo!
Is it me, the lighting or did the blue get darker (in a good way!)
I like that the glasser has to sit there and watch :lol:
SHSU
Kmsp1264
She is really looking GOOD! The windshield usually is a problem for a lot of us, but looks like no issue for you
SHSU
Watermann
Very nice work, you're really flying through this.:thumb:
Kmsp1264
2884F529-E906-453B-8DB2-33205D6D2F84.jpeg Inside light makes it look a little different.
windshield went better then I thought, all sealed underneath. The center glass needs a new seal on the bottom, I think I’ll need to look for something that will slide into the groove.
many comments on the ducting underneath?
The instrument panel is in just need to make the top piece then I can move on.
Kmsp1264
SHSU
You are flying through this thing. She will be ready to be back on the water before you can break quarantine!
Can you define the "ducting" question? Not sure what area you are referring to.
SHSU
Kmsp1264
I have the exhaust fan mounted, just wondering if anyone knew how Starcraft mounted the the ducting underneath, I have hose connections on all the intake and exhaust clamshells. From what I read I need to have a duct to the exhaust fan from the the lower 1/3 of bilge, I’m curios if Starcraft had more ducting, each clamshell has a duct connection underneath
SHSU
Ah, I will have to deffer to an IO guy for that.
SHSU
mattsteg
My boat isn't original, but just has vent duct drops to the bottom of the bilge.
