Re: '00 200HP Yamaha Trims Down, Not UP
you say both the pan switch and the trottle switch only make the relay click for UP.
ok.
as you didnot post the full model number I am going to go by its a lefthand HPDI 200.
LZ
anyway, remove the electrical panal cover from the stbd side of the engine, you will see a 4" by 2" box with a 10 Ga blue wire and a 10 Ga green wire a 10 Ga black wire and 3 18Ga wires,blue,red and green.
now were going to test the up control circuit.
dissconnect the plastic connector with the 3 wires, use your multimeter and connect between the ground and blue terminal, hit the button up. you should read 12V, if not test the circuit on the blue wire back to the box. a quick test on the relay is to jump the blue wire at the relay connector to a 12V power tap, starter relay works well and is close.
if it goes down and not up it indicates the trim motor is ok and you either have a bad control circuit or a bad relay.
do a forum search and you will find I have posted a complete test before.
