'02 Merc 4 Stroke - Diagnosing bad ECU?
Thirsty Endgrain
s/n 0T733923
Hi all,
Coming in the other day it started acting erratic, would idle and then bog down hard as soon as I put it in gear. Limped home at 6 knots, admittedly longer than I should have with a bogging engine but it was getting late/dark.
Assumed carbs since it's a Mercaha known for plugged jets/gumming issues, though I've always run Quickleen and the other additives to keep fuel stable since buying it and rescuing it from someone who couldn't get the carbs cleaned. That was a couple years ago and I figured it was time for a cleaning again, which I did. Put it all back together and realized it only has spark on cyl's 1/4. 2/3 had no spark, so I replaced the coil. No change, so I traced wires back to the ECU, which is providing only intermittent signal to the 2/3 coil. Does this confidently condemn the ECU? Are there any other lines of troubleshooting I can do? I already ordered a used one off of ebay to get it on the way, but if I'm missing something that someone knows of I'd appreciate any advice. Thanks.
Oh, I made a video of it surging in and out of spark, not sure it would help troubleshooting, but figured it couldn't hurt. I was poking around at the wires to see if it was a loose connection somewhere, but couldn't confidently reproduce the surging traced to any one wire/harness or the other.
dingbat
s/n 0T733923
Hi all,
two cylinders out points to stator
Starts on page 112
boscoe99
75 or 90 HP model?
The Yamaha F75 and F90's of that vintage did not have an ECU. A CDI assembly was used. Capacitor discharge ignition system.
Thirsty Endgrain
Thirsty Endgrain
75 or 90 HP model?
Right thanks for the correction, CDI. It's a 90hp. Would the erratic signal from the pinout of the CDI to the coil possibly be caused by the stator, or is it more likely to be the CDI? Is there a way to test this?
dingbat
From the above attached manual...........pages 111 and 112
If (#1 and/or #2) or (#3 and/or #4) is not sparking, swap the White/Green and Green/White stator wires and retest.
If the problem moves to the other cylinders, the stator is likely bad.
If no change, replace all CDMs.
A continued no spark condition on the same cylinders indicates a bad trigger.
boscoe99
Do you see any markings on the CDI box? If so, what are they?
If a Yamaha box is installed, the output of the CDI to the ignition coils can (should be) be tested. As shown below. If the CDI output is normal then perhaps it is the ignition leads. If below normal then test for the inputs to the CDI.
Thirsty Endgrain
I'm awaiting a DVA adapter, didn't yet have one. I tried using the MAX function on my multimeter to test the stator and CDI output, but I don't think the readings are accurate with that method. One thing is for sure though, the output to the affected 2 cylinders from the CDI is abnormal/absent.
Thirsty Endgrain
Tested the CDI and stator output with the DVA. Stator is 16.2V on all three wires, normal according to the manual. CDI output is 125V to cyls 1+4, but erratic to cyls 2+3. So I'd call that close to a smoking gun. I have an ebay CDI arriving tomorrow, I'll update when I get it in and test 'er out, thanks for the help so far boscoe and dingbat!
Thirsty Endgrain
EDITED below, I made a dumb dumb error in testing and assumed that a black wire was ground when it was in fact a signal wire, if you read already I've deleted the error and changed it...
More testing and more testing:
Replaced CDI with ebay one, it seemed to work for like 5 seconds and then started having the same problem. That could have happened with the other CDI too since the issue is erratic. So I guess it's not the CDI.
Crankshaft posn. sensors read:
Resistance test: 515 ohms on both legs. Check.
Leg 1: 5.6V to CDI
Leg 2: ~.75V to CDI.
Shift interrupt switch is grounded, and breaks ground when depressed (normal).
Voltage specs from manual for CKP sensor outputs are 2.8-3.4V @ 400rpm, and 6.5-7.8V @ 1500rpm. I'm testing at about 1000rpm, so 5.6V sounds reasonable. But the low .75V voltage from the second leg makes me think CKP now, of which I just learned that there are 2. So one failing CKP that ostensibly serves cyl's 2+3 is starting to make some sense.
Voltage output from all three stator leads is 16.5 around 1000rpms.
Voltage output from rectifier regulator is 14.6V at around 1000rpm which according to the manual is low, it states 18-22V at 1000RPM. However, stator input to rec/reg. is good, see above. So this is the other area where I can see a potential problem, manual states to test input voltage if reading from output is low, but input voltage is within spec. Unresolved.
I ordered a new CKP just in case that's the issue, but would really appreciate any input about the trees I'm barking up...
Thirsty Endgrain
Just learned that there is also the term "pulser coil assembly." Which contains the crank posn. sensors? I was thinking one could be out of adjustment, though I'm not finding gapping clearances in the manual...
Thirsty Endgrain
Well I don't know if anyone is following along but to put this to bed in case it helps anyone. I replaced the pulsar coil since one of the crank sensors was giving an erratic reading, the unit came with the wiring harness that also feeds the CDI and the shift position sensor. When I replaced the pulser coil ass. I just plugged it into the existing harness to not have to dig the old harness out and make the connections to the shift switch that are kinda buried. SAME problem. Bad reading from the same 2+3 leg of the sensor. Reaching the light-a-match-and-throw-it-in phase I calmed myself and went through where an issue lie that could come from? Well, at that point I've tried new CDI, pulsar coil, and the only thing remaining was a short 4" long section of harness, I swapped the section in that came with the pulsar coil and voila. She purrs again.
The strange thing is that wiggling the harness did not really seem to cause or cure the issue, it was erratic whether I was touching things or not. That's what shied me away from that line of troubleshooting. I re-learned something I've learned what should have been enough times at this point, but to always ALWAYS check the simplest things first. I should have checked each wire for continuity/resistance regardless of the results of the wiggle test.
Anyone in need of a CDI or pulser coil assembly for a 2001-2006 mercury/yamaha 90hp 4 stroke?
boscoe99
If it is of any consolation you are not the first to throw parts at a problem and you certainly won't be the last one.
Modern self diagnostic equipment can make the problem worse. Folks get a code, say one relayed to sensor X, and then buy and replace sensor X. Sensor X was not the problem.
dingbat
Unfortunately…….you can’t buy the experience to go along with it
ALWAYS start with power and signal from the source
