My Yamahammer was acting up a little last season, I contributed to bad gas.
prior to this season I drained the tank,added alittle gas and drained it again. Added a drier and high test gas. Boat ran perfectly on several outings. The last tripout it died at the dock (lucky). Itwill start and die after 30 sec. With massive amounts of gas in the intake. First thought a injector was stuck, but all four plugs were fouled. Found the fuel line from the fuel regulator to the intake was pumping fuel in to the intake.???? Is the regulator bad or is the pressure sensor bad?? How do I checkthe sensor?? Tryingto avoid towing and hauling to high priced marinia. Thanks forany Help!!
