Hello everyone,
I think I've narrowed down my problem as far as I can go without a little outside assistance...
The motor turns over but will not start. I've tested the + terminal on the Ignition Coil with the key turned on but am getting 0v.
I have seen this troubleshooting doc but am not sure how to go about testing the tach, instrument panel, wiring harness, or key switch. Is there a fuse I should check first?
My Tach is frozen at 1,450 rpm (not sure if that's a sign of something) and the Voltage/Fuel/Oil guages don't do anything when the key is turned on or when the motor is cranking. My bilge, blower & horn all work, as well as the Total Hours meter.
I also tested the two gray wires that go to the negative terminal on the coil and one of them was grounded and the other wasn't. I am not sure why there are two wires coming to the coil, I thought I only saw one in the wiring diagrams.
I must admit that electrical problems are not my forte so I will not be offended if you spell things out in layman terms
Here are pics of my tach and key switch in case you need to refer to a specific terminal:
Thanks for your assistance.
Mark
1997 Wellcraft Excel
Alpha I Gen II (0K057217)
MCM 5.7L (0K149129)
Mark
MCM 5.7L (0K149129)
