Re: 1 question before outdrive install
Bruce,
Just to clarify--I have the 1999 SX-M 1.97. To drain that, I just have the screwdriver plug at the bottom of the lower unit.
My SX was at the end of the Volvo/OMC transition, and does not have the squared off OMC style trim cylinders. It has the non-rebuildable VP cylinders.
Even though my boat was bought second-hand, it was originally purchased at my local marina, and they still had the original bill of sale, which they sent to me, and all of the drive/engine serial numbers match, so nothing has been replaced. Regal boats verified numbers too.
And the drain plug I'm referring to is on the engine oil pan of a VP factory '99 3.0 with a drain plug. I'm not talking about a drain plug on the drive. I made, perhaps, an assumption that the larger engine blocks may also (conveniently) have utilized an automotive style oil pan, and kept an oil drain plug in there as well. (Doesn't hurt to ask...) My block also has the hose fitting on top of the oil dipstick tube to attach a garden-hose-style pump fitting. I just found it way easier not to use it to drain engine oil.
As for the adhesive...that was recommended by Don in a post from about two years ago....I'll see if I can find it. Don also chastised me for putting adhesive on the exhaust bellows, as I did not know any better (at the time...) so I'm just trying to help some of these people with ideas that may put them on the right track until others (like yourself) can chime in.
Perhaps the instructions for the SX A and SX M are different in where they specify to use adhesive?
