stephenca118
- Aug 23, 2021
- 15
I picked up this 1970 bayliner for my brother. It has a 1970 Chrysler 105. Last licensed in 2013. Supposedly the lower end had been rebuilt by a marine shop.
I finally got it running yesterday after rebuilding the distributer and syncing the carbs and timing. And a whole lot of other stuff.
Anyway, after cranking for about 30 seconds it started, ran rough for a few seconds then just purred at idle. I ran it about 30 seconds more looking for water out the exhaust bellows port and nothing. Shut it down. It looked like some water spray was coming out the....what is it called......CRS.....sorry. That opening just above the prop.
I tightened the muffs around the water inlet to try to force more water in and ran it another 30 seconds with no water coming out the exhaust bellows.
I pulled the gear case to check the pump. Drained the oil, it was clean and blue but had some debris in it but no shiny metal. No water in the oil but I doubt the boat was ever in the water after the gear case was rebuilt.
The cavity had water in it. Removed the pump housing and I am questioning its condition. Photos attached.
Is that the correct impeller? The one I ordered looks different.
Should I replace the housing? It looks very pitted.
I am not new to mechanics, even I/Os but am new to outboards.
Thank you very much for your time reading this and for any feedback.
Steve
Steve
