110 Johnson, sputtering and coughing
Capt dave 258
Low 80's, 110hp Johnson that I can't get to run smoothly. VRO has been deleted. Plugs and coils are good. Fuel filter replaced. Had the carbs cleaned but not much faith in the mechanic. When I got it back it was leaking gas from the small fuel lines. He didn't replace them and I had to bring it back to have him do so. Compression is 110 in two cylinders and 105 in the others. Sputters and coughs. Thoughts, ideas?? Thanks
  • 20240203_152558.mp4
Remove cylinder head on the one with 105 PSI.----Likely it is suffering from broken piston rings.-----Very , very common failure !!
